View unanswered posts | View active topics It is currently Thu Apr 09, 2026 9:10 pm
Reply to topic  [ 11 posts ]
Head Bolt Tension
I've searched and cannot find it, so.
What is the head bolt tension for the standard G150 in the Belletts?
Cheers Rob
Sun Sep 18, 2016 9:24 am
Hi Rob
I think I recall standard is 7kgm = 50 ft lbs
I go higher to about 9-10kgm = 68-72 ft lbs
Depends on 'feel', Belletts have heapem big head bolts.
Best to
- clean out the thread with a tap
- use Assembly lube on the thread and under the head
Bolt (at a push could use engine oil but not quite as good)
Sun Sep 18, 2016 12:14 pm
yeah in the manual its 6-7 kgm
Im pretty sure i did mine a bit tighter though.
Mon Sep 19, 2016 3:06 am
Thank you everyone for the info.
Mon Sep 19, 2016 10:45 am
So does anyone have the correct tension for the rocker stand bolts ?
Sun Jan 08, 2017 9:44 am
I'm going back a long time, but the G150 has two head bolt sizes if I recall, 17mm for the 3 Bearing and 19mm for the 5 bearing, so I would assume two different settings, be careful about overtightening.
Ted (Teditor) Freeman
Ted Freeman
Sun Jan 08, 2017 10:51 am
Hi Rob,
I do have that information, but it is at work.
If I don't remember to post later, call meon 02 4393 2833
Warren.
Sun Jan 08, 2017 7:33 pm
Here is the table of tightening torques for 5 bearing engines,
Lewis.
Sun Jan 08, 2017 7:56 pm
Yippee.
Thank you so much
:D
Sun Jan 08, 2017 8:53 pm
Lewis beet me to it.
That is the same book I have.
Mon Jan 09, 2017 4:27 am
Tis good 67GT :D
Wish it was easier to clean the head and block of the accumulated gunk.
40+ degrees then constant rain ... blah. Hard to get anything done at all.
Head is nice and clean now.
Next is to clean bolts and rocker gear, then if I can get some fine weather, the block.
Cheers everyone :D
Fri Jan 13, 2017 3:27 am
