[ 11 posts ] |
RobSA
I've searched and cannot find it, so.
What is the head bolt tension for the standard G150 in the Belletts?
Cheers Rob
| Sun Sep 18, 2016 9:24 am |
Asroc66
Hi Rob I think I recall standard is 7kgm = 50 ft lbs I go higher to about 9-10kgm = 68-72 ft lbs Depends on 'feel', Belletts have heapem big head bolts. Best to - clean out the thread with a tap - use Assembly lube on the thread and under the head Bolt (at a push could use engine oil but not quite as good) Cheers J
| Sun Sep 18, 2016 12:14 pm |
yeah in the manual its 6-7 kgm Im pretty sure i did mine a bit tighter though.
| Mon Sep 19, 2016 3:06 am |
RobSA
Thank you everyone for the info.
Cheers Rob
| Mon Sep 19, 2016 10:45 am |
RobSA
So does anyone have the correct tension for the rocker stand bolts ?
| Sun Jan 08, 2017 9:44 am |
Teditor
I'm going back a long time, but the G150 has two head bolt sizes if I recall, 17mm for the 3 Bearing and 19mm for the 5 bearing, so I would assume two different settings, be careful about overtightening.
Ted (Teditor) Freeman
_________________ Ted Freeman
| Sun Jan 08, 2017 10:51 am |
67GT
Hi Rob, I do have that information, but it is at work. If I don't remember to post later, call meon 02 4393 2833 Warren.
| Sun Jan 08, 2017 7:33 pm |
Early GT
Here is the table of tightening torques for 5 bearing engines, Cheers, Lewis.
| Sun Jan 08, 2017 7:56 pm |
RobSA
Yippee. Thank you so much
| Sun Jan 08, 2017 8:53 pm |
67GT
Lewis beet me to it. That is the same book I have.
| Mon Jan 09, 2017 4:27 am |
RobSA
Tis good 67GT  Wish it was easier to clean the head and block of the accumulated gunk. 40+ degrees then constant rain ... blah. Hard to get anything done at all. Head is nice and clean now. Next is to clean bolts and rocker gear, then if I can get some fine weather, the block. Cheers everyone
| Fri Jan 13, 2017 3:27 am |
[ 11 posts ] |
Users browsing this forum: No registered users and 11 guests |
