View unanswered posts | View active topics It is currently Wed Apr 08, 2026 10:05 pm
Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3
TIE ROD ENDS
Asroc66 wrote:
As I said I take no responsibility - investigate with your own merits
Arrr the black art that is Bump steer
For those with keen eye sight amongst us......
The tape is 6mm
Which one is which?
This is my '72 Sport
Given that most Belletts are lowered in front, including mine, without actually measuring anything, is straight better?
Thu Nov 26, 2020 4:51 am
Steering arm angle (be horizontal or not) makes no difference. They can be vertical with 8 twists and turns and still work, but what is critical is where the small ball joint is mounted to the steering arm in relation to the upper and lower ball joints. That's where problem begin with bump steer and all sorts of issues.
It's the same on the inner end and where the steering knuckle on the end of the race is located in relation to the upper and lower control arm mounting points.
That's why I cringe when I see people start moving racks, inner mounting points, ball joints, spring rates, lowering amounts and God knows what else when they obviously have no idea what moving those things does to the basic geometry because it can be bloody dangerous.
I said as much before but it falls on deaf ears sometimes.
Sat Nov 28, 2020 11:08 am
I am retired now but refurbishing steering joints tie rods and ball joint was my main business for many years. I still have my gear so if you are stuck you can call me I'm sure I could help. 0408 752 070. For rubber boots try Repco
Sat Jan 01, 2022 2:09 am
