View unanswered posts | View active topics It is currently Thu Apr 09, 2026 4:23 pm
Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3  Next
project Betty
Awesome, another one saved! :D
Sun Aug 30, 2015 9:02 am
next step your becomes a deluxe ...what a good score ..we are all watching ...keep at it cheers davo nice gt mirrors also ...worth $100 alone ....
Sun Aug 30, 2015 9:10 pm
Looks like good GT mirrors, theres value to start with!
Great period wheels on Betty also, great choice.
Mon Aug 31, 2015 12:06 am
looks like an auto as well ??
Mon Aug 31, 2015 12:47 am
Car(s): 67 bellett
Mirrors should scrub up ok :D. Yep it's an auto :( . Has really nice black interior (except for the carpet that went in the bin last night yuk)all chrome trims, some badges, remote booster. Spare sets of tail lights in really good condition, even found a few boxes of new pbr brake parts and a couple of old carbs in the boot. Might try to fire the motor up tonight wish me luck
Mon Aug 31, 2015 5:35 am
Car(s): 67 bellett
Busy weekend the deluxe got a tank flush, fresh fuel,fuel filter,oil, plugs, and a degrease, after a little mishap with the the distributor cap that is different to Betty's??? She is alive and well :D runs very well, no smoke, no rattles I'd got as far as saying it actually runs and sounds better than Betty
Sun Sep 13, 2015 10:15 am
Nice! The motors almost always run, in my experience.
Different dizzy cap? Both cars are '68 models, indicated by horns both being on the drivers side. (Earlier models have one each side) Does one have an alloy head? If so, check the block casting on drivers side. G150 or G161?
G161 is Florian or Chev Luv 1600. (Tappet cover is Florian/Bellett type)
Florian/Luv have a dizzy and cap with the lug on the opposite side.
Why? Who knows?!
Sun Sep 13, 2015 12:25 pm
Car(s): 67 bellett
Both g150 cast heads. Not sure what the go was with the dizzy bit the plug order was different coming off the distributor
Mon Sep 14, 2015 6:22 am
Hi
With the dizzy, it can be 180' out of when assembled or rebuild when the drive off the cam is reversed
No biggie as the firing order is unchanged obviously
If you turn the dizzy upside down you will see the offset slot
So if the drive is put in 180 out, the dizzy has to be turned to match up the slot
I have 2 cars set up 180 out, no problema
By your picture though your plug location is correct for factory setting
If I miss took the issue the perhaps u have an early cast iron dizzy and a later aluminium one which can also perhaps explain as points, rotors and caps are different?
Mon Sep 14, 2015 8:45 am
Asroc66 wrote:
Hi
I just went through the dizzy issue myself with Donkey's engine swap.
The replacement engine had the correct early smaller dizzy cap and points but it was buggered so I put donkey's one on but it is the later model dizzy with bigger cap and points. The points in this one were cactus (broken spring) and my spares were all for the early type.... :?
Fortunately I had a spare later model dizzy at my bros place and I scavenged the points out of that one.
Mine also runs 180 deg out
Mon Sep 14, 2015 10:20 am
Car(s): 67 bellett
Ah ok that makes sense then. I took the Leeds an cap straight off Betty (red set) picture miss matched Leeds it came with
Mon Sep 14, 2015 10:28 am
And Bingo was his namo...,, 8-)
Mon Sep 14, 2015 10:51 am
Car(s): 67 bellett
Finally getting some shed time (Dont mind the mess I've been busy) the decision has been made on my first victim which is the Mexican bellett with red boot :twisted: :lol: if all goes to plan she will be a pig on a spit by mid year. Meanwhile I need to build a mezzanine in the shed I'm out of room as there's been a new addition to the bellett family
Fri Mar 04, 2016 10:40 am
Be careful they are like rabbits 1 is ok 2 then you end up with heaps and finding/building shed space.
Fri Mar 04, 2016 11:32 pm
Nobody ever owns just one! soon you will need to be extending the shed!
Sat Mar 05, 2016 11:30 pm
Truer words never spoken......
One to show
One to go
One to daily drive
One or more being restored.......
Sun Mar 06, 2016 12:21 am
Car(s): 67 bellett
Lucky i left myself room for another shed. One to show, one to go the other is parts car. I wouldn't mind another with less rust though haha I hate rust and I have lots of it
Sun Mar 06, 2016 12:53 am
One to show
One to go
One to daily drive
Donkey is a one in all show n go, daily driver..... with another 4 projects on the side :mrgreen:
Sun Mar 06, 2016 7:03 am
Car(s): 67 bellett
Tonight's effort dash/under dash removed. Finish off tomorrow night an start in the engine bay
Thu Mar 10, 2016 9:20 am
Looks like the koala bear is hanging in there and keeping a close eye on the progress
Thu Mar 10, 2016 9:32 am
Users browsing this forum: No registered users and 40 guests
