View unanswered posts | View active topics It is currently Thu Apr 09, 2026 12:41 am
Reply to topic  [ 20 posts ]
Brake pistons
Ok Guys
Now please refrain from laughing but.....
Has anyone got serviceable GT brake Pistons that they are willing to part with
Out of 9 I scrummaged so far only 1 is useable
So I need 3...
Also need a set of dust boots as per photo
Can anyone help
Wed Sep 09, 2015 5:40 am
Hi James,
Not sure about the rubber boot, but I would think a good machine shop could spin up some new pistons for you.
Wed Sep 09, 2015 5:45 am
Hi
Thanks for quick response
Am wondering if this is uncharted territory or has someone been down this road already?
If so then could someone please give me details of shop, cost, how well they worked etc
Difficult to find someone with such talent locally
Wed Sep 09, 2015 6:05 am
Give my mate Glen Hunt a call 3889 6669 (is his work number, Stainless Steel Sleeving, Brendale, QLD)
He should be able to point you in the right direction, may posiblely machine up himself.
Wed Sep 09, 2015 8:11 am
Thanks Stickman
I was thinking the best way was to sleeve.... Surely this must be the case
The Pistons are quite complex in nature
Wed Sep 09, 2015 8:31 am
Hi James, I used Jaguar Pistons in mine, check my post in the brake section on this site. Geoff
Wed Sep 09, 2015 10:44 am
BHSS in Brisbane some they made the first set they machined and chromed them. So you have options.
Wed Sep 09, 2015 10:53 am
Thanks guys
So it it possible to sleeve?
Or machine down and re-chrome ...... Wondering how this option effects the central
Pin clearance etc
Wed Sep 09, 2015 11:01 am
pr95's jag ones have no pin and seem to have no il effect. They were done by a professional brake repairer.
Wed Sep 09, 2015 11:02 pm
Spent the morning on the phone and ended up visiting local brake, clutch, machine / fabrication shop
Left them a sacrificial piston to de-construct and estimate cost of fabricating with central shaft in stainless
Will let you know if doesn't cost one's 1st born
Thu Sep 10, 2015 8:55 am
In the past, I had a number of these pistons re hard chromed and then machined. Unfortunately, the guy who did them passed away but there must be some body who can do them.
As for the rubber seals. I might still have a NOS kit here. Problem is finding it at the moment, since we moved house, nothing car wise has been unpacked.
BGT brakes in Dandenong, Vic. can overhaul the calipers. (03) 9792 2806) Ain't cheap, about $500/pr i think it was. Or maybe $250 pair, I can't recall now. Call them...... they know Belletts. Most of BCCV go there. Pretty sure they use Jag stuff in them. They look like brand new when you get them back.
Thu Sep 10, 2015 9:42 am
No problem with Calipers
It's all about the Pistons
Apparently because the seals are seated in the Calipers and not the Pistons means the Pistons are sacraficial
Thu Sep 10, 2015 9:47 am
BGT overhaul the whole thing.
I imagine water in the fluid is the final enemy of the pistons as they start to corrode the hard-chrome.
All of the pistons i got re-done were usable. The guy ground them back to base metal, hard chromed them and then re-machined back to size. I organised about 6 sets i think at the time for BCCV members.
Thu Sep 10, 2015 10:07 am
Brakes still good to Glenn, no misting around the calipers, no leaks and disc's are fine, all thoroughly checked before Toowoomba .
Fri Sep 11, 2015 5:00 am
Hi Guys
Dropped a set of pistons off with specialist Ceramic Coating Business
They will take a look
If pitting not to bad may be able to help]
They do some weird and wonderful treatments on all sorts of parts for Tassie Targa cars including Jason White's Lambo.........
Will let you know
Mon Sep 14, 2015 4:26 am
Spoke to Todd at Ceramic Coatings Tasmania this morning.
He is confident he can coat a set of Brake pistons with this space aged NASA product.
He has a coating for everything.......
Opens up a whole new world especially to those 'Boy Racers' amongst us
Will keep you informed
Mon Sep 14, 2015 11:23 pm
called into better brakes southport to see how my front brake arrangement was going he has it all apart and is also coating the pistons or whatever said he will fit some other valiant or whatever bits to it hes confident will let you know the outcome cheers davo the guy at better brakes is wayne number is 07 55710271 or 0400006340
Tue Sep 15, 2015 3:06 am
I may have said this before but the thing about Bellett Brake pistons (which they did indeed pinch the design from Jaguar - Dunlop) is the central pin
Apparently its function is to limit movement or 'knock-off' of the piston/pads when you take your foot off the brake thereby reducing pedal travel
This is the main reason I am trying to resurrect the existing pistons rather than finding different pistons and machining them to fit
Tue Sep 15, 2015 3:31 am
Well have some information
http://www.powertrackbrakes.co.uk/wcylinder.html
The front pistons are off the Jaguar 420G saloon built from 1966-1968... small run which makes then rare in itself
Calliper Rubber Kit : Girling SP2565
Brake Pads Bellett : DB704 (No longer available - save your backing plates and have them re-bonded)
Tue Sep 29, 2015 10:10 pm
Just picked up the pistons from the Ceramic Coaters
3 are definitely useable, 4th touch and go as likely to 'seep' which may be OK on weekend driver but not daily driver so I will give it a go.......
Interim step to Sleeving if pitting minimal at about 1/3 cost........
Wed Sep 30, 2015 12:26 am
