View unanswered posts | View active topics It is currently Fri Apr 10, 2026 9:12 am
Sway Bars
Hi Guys
Can someone tell me if the sway bar off a PR91 is interchangeable with that of a PR20 4-door
I am led to believe the GT is thicker?
Do they use the same mounting points and hardware/hangers
Are the bars the same size at each end
Many thanks
Fri Jun 12, 2015 5:56 am
Always seem to read these techy questions at night, so dont just slip out for a look, but I'm pretty sure the GT bar is thicker, but hung the same way. Just larger diameter holes in the rubbers.
Fri Jun 12, 2015 11:37 am
Hi J.
Outer bushes and brackets same part numbers. Inner bracket same but bush different.
GT has a larger diameter in the bar except for the ends.
Fri Jun 12, 2015 1:37 pm
Many thanks
That was what I wanted to hear
Fri Jun 12, 2015 10:43 pm
Sedan bar is 19mm. GT is 21mm.
In all honesty, the bar is not the problem on a Bellett front end..... It's how it's mounted. They're useless.
Have a look under the front of my race car and you'd see how to fix it properly.
Sun Jul 05, 2015 2:04 pm
Old thread but i just checked the diameter of my front sway bar on the Sport. Using vernier calipers its around 20.4mm (close to 21) diameter. I wonder if in fact that's the same as a GT? I am assuming it would be as the rest of the Sport uses all GT stuff.
Mon Mar 25, 2019 6:22 am
