View unanswered posts | View active topics It is currently Thu Apr 09, 2026 4:54 am
Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
Sedan shell only WTB (any year)
Hi guys,
Just looking to see what is about the place. I've got a shed full of doors, bonnets, engines etc and realised that I have enough to build a car but no car to bolt it all on to.
Does anyone (ideally in Adelaide but will look elsewhere especially Melbourne) have a shell minus engine/interior that is doing nothing or better yet getting in the way? I'm trying to avoid having to weld up too much rust so want the rear guards, sills and floor to be good. Behind the front guards can be dodgy but not too much ;)
Anyway, let me know what you've got kicking around. As I said, looking at shells only to build back up as the budget is pretty tight on this one.
Thanks!
R.
Mon Jan 19, 2015 2:29 am
What a good idea, Ross.
I can only offer this one.
Yeah, its a long way from home, but it is a pretty good body. I've had it a long time, and it would be good to see it revived. It is a pretty bare shell, but with complete suspension. There is not much rust at all, sills are great, tail behind the bumper, behind the front guards, boot floor all solid. Interior floor was perfect, but may have some little holes by now, I'll have to empty the parts/junk out to check. There is some in the back guards, which has already been cut out. There is also just a seam starting in the drivers tower.
It would be a lot easier to do than some.
If you like I could get a few more pics.
Tue Jan 20, 2015 11:22 am
Hey Matt, that's looking like a good base.. What are the floors like, and the engine bay?
I'll PM you to discuss further.
Thanks for the quick response!
R
Thu Jan 22, 2015 3:18 am
Here are a few more pics, now I've pumped the tyres up!
Solid bootfloor.
Drivers footwell, few small holes.
Solid rear floor.
Valance removed, but I have one. Small holes on passenger side.
Solid under battery.
Worst bit of sill, small holes at rear of drivers side.
Sat Jan 31, 2015 12:08 pm
Passenger side tower.
Probably the worst bit, drivers tower. Still strong, but will need a repair.
Sat Jan 31, 2015 12:25 pm
good shots matt.................
Sat Jan 31, 2015 3:05 pm
Thanks Matt :)
This thread should be called, 'See where they rust'! It's got all the 'usual' Bellett rust but not in a bad way, just starting to show.
I think I'll be able to pull that back from the edge and get it on the road... Thanks for the extra pictures and I think I'll be seeing you very soon ;)
Ross.
Sun Feb 01, 2015 10:41 pm
she is not bad at all, farmer.
pity i didnt know it was needed a few weeks ago. could have brought the trailer with me as well?
and you didnt show me that side of the shed either???
Mon Feb 02, 2015 11:05 am
Mate, you didnt stay long enough! I was meaning to go there, and I didnt even show you the one in the shed!
Next time you need to take a longer break.
Mon Feb 02, 2015 12:29 pm
2ldohc wrote:
Thanks Matt :)
Ross.
Excellent! See you then.
Mon Feb 02, 2015 12:31 pm
He needed to get back home for a coffee............
Mon Feb 02, 2015 10:03 pm
Hey Ross the one I got off you and Dave is available.
Thu Feb 05, 2015 9:51 am
nothing to do with this tread actually, but anybody know what has happened to the Ex Vic green sedan with DOHC injected engine?
Any progress on getting it back on the road ?
Thu Feb 05, 2015 10:01 am
I should let Claws answer that question
Thu Feb 05, 2015 10:32 am
Hi Glenn,
Green sedan still has a bit more work to get it going. Have just got a set of extractors done, still have some magna brake parts to get which are just about impossible to find. Re upholstery of interior is half done and motor could be ready for its first start up next week with a bit of luck. As far as getting it registered in SA that could be a whole new thread on its own but I,m just working on it bit by bit at the moment and enjoying it when I get the time in the shed. If its not on the road this year it will at least be going to our local race track , Mallala for a day :)
Thu Feb 05, 2015 11:23 am
claws wrote:
Hi Glenn,
sounds good so far...... as for rego, it just has a head from a later engine on it ;) ;)
Fri Feb 06, 2015 12:33 am
Hey Glenn,
Did you work on the green twin cam car.
A photo of the engine bay would be helpful if anyone there has one.
Need something that could help me get the spark plug leads in the right order.
All I know is that this was sort of a group project by members over there.
Not sure if it might have been you that told me that a few months ago or someone else from Melbourne.
Fri Feb 06, 2015 1:30 am
claws wrote:
Hey Glenn,
I don't have any photos handy and from vague memory think firing order is same as Bellett OHV but could be wrong
A number of us worked on the body work, late into the night many times !
Fri Feb 06, 2015 2:31 am
Hi Claws,
I know where there is an early model magna sitting in someone's front yard that has been there for yonks if your interested. you may have to buy the whole car though. I think it is a TP or TN model. I live at Glengowrie at the moment and walk past it everyday coming home on the bus.
If you want me to ask I can knock on the door or give you the address if you like.
Fri Feb 06, 2015 10:42 am
Thanks Jeff but not needed. I only need a few clips to hold brake pads in so will wait till one comes up locally.
Mon Feb 09, 2015 2:23 am
