View unanswered posts | View active topics It is currently Wed Apr 08, 2026 11:58 pm
My 74 Chevy Luv
Leave it CRUSTY!
Like Donkey's :shock: :?
Fri May 23, 2014 1:23 am
I polish my crust!! :D
Fri May 23, 2014 4:50 am
We only have buffalo skull up here in the nt, not sheep skulls, and I don't think my visor will hold the weight........;)
Fri May 23, 2014 8:07 am
Its been a while since I was on here!
Couple of new pics of the Luv
I am going to be supercharging the engine with most likely an AMR500 (just trying to find a decent one for cheap). I have a 45mm DCOE Weber to use with it.
Idea is to run the SC just forward of where the stock carb sits and the side draft weber on a 90 degree home made manifold. If I run a 2:1 pulley it should see around 8psi max and this will keep the unit under its 16000rpm redline.
Anyone have any tips or ideas here? It will be a big trial and error system for me currently.
Wed Nov 19, 2014 11:16 pm
Sun Jan 18, 2015 5:22 am
I think this is same type? On a Corolla. Might give you some ideas on mounting perhaps.
Sun Jan 18, 2015 7:52 am
That's such a cool truck!
Tue Jan 20, 2015 8:54 am
Interesting snout setup to line up the pulleys. To be honest I have put the supercharger idea on a bit of a back burner while I work on my Cortina but still keeping an eye out for an AMR500 cheap.
Wed Jan 21, 2015 8:23 pm
