View unanswered posts | View active topics It is currently Wed Apr 08, 2026 5:29 am
CHEV LUV UP AGAIN
I GUYS ON GUMTREE IN VICTORIA $450 85 LUV NEEDS BIT OF WORK ...I THINK THIS ONE IS SPOKEN FOR CHECK THE ADD ...SAYS ''SUIT FARMER'' :lol: DAVO
Tue Jun 24, 2014 11:58 am
So people are selling cars just to Farmer now, Classic Davo.
On another note there is a 79 Luv 4x4 near Bendigo for $750 on Gumtree doesn't seem to bad.
Tue Jun 24, 2014 12:44 pm
Looks as though farmer will need a biger farm .gricey
Wed Jun 25, 2014 11:13 pm
One in port maquarie 400
Thu Jun 26, 2014 4:38 pm
Not Too bad, More Luv on Ebay in Young NSW.
Another Early Luv for $300 (would considder it if it was closer)
http://www.ebay.com.au/itm/Chev-Luv-Dri ... 4ad7916a7b
Thu Jun 26, 2014 11:58 pm
Yeaaaah, well its an Isuzu, and its cheap, so it would suit Farmer! ;)
And look! This one is in Young! Thats like, 70ks away! Hmmm, .......if its early enough, it will be Florian motored........hmmmmm. I don't have a Luv........
Tracy read this and suggested I might be going on "Farmer wants a Wife"! :?
Oh dear. :|
Fri Jun 27, 2014 10:16 am
I think the Young luv would be a wrecking only vehicle by the look of it!
It is an early one which means it should be a G161 not a G161z but a latter series the the Australian delivered Florian.
SA Dave has one in his red ratter and it goes pretty well!
If its was closer it would be a good parts car for me as it look like it has its heater!!
Fri Jun 27, 2014 10:38 pm
but it has a 1992 Rodeo chassis and running gear, presumably the engine also
Fri Jun 27, 2014 11:39 pm
Sorry Glenn this is another one on Ebay in Young for $300, definatley should be early running gear.
Sat Jun 28, 2014 12:28 am
OK, thanks. Not a bad idea though.
Sat Jun 28, 2014 7:58 am
It would be interesting to see how far they got with the conversion. You would think it would be a fairly easy conversion compared to some considering the utes are based an a 2 rail chassis that everything is mounted to.
Sun Jun 29, 2014 9:39 am
Hey Josh, do you want me to go see about the Young Luv? I could pick it up, store it and send you the heater.
I'm in Sydney this week, but home next. If you want to buy it, I can pick it up. Whaddyareckon?
Sun Jun 29, 2014 12:32 pm
Wow thanks for the offer Matt, I dont want to be responsible for a divorce though!!
Is there anything on it you would want? timber tray for one of your wasps?
I am checking that the engine is the G161 too as that might be usefull for you?
Sun Jun 29, 2014 11:38 pm
See, its probably ok if its not mine! ;)
A g161 might be handy some day, and the tray might be useful too. If so and you don't need them, I'd buy them off you.
Whatever you like, mate. I can find a spot behind the shed. :D
Cheers, matt.
Mon Jun 30, 2014 12:38 pm
That would be amazing Matt, am trying to get a photo of the engine and tray to confirm
condition and that its a G161 not a Z. Both are yours if you want them.
Got photos.
Tue Jul 01, 2014 12:33 am
Ah-ha, definately a G161.
Ok mate, so if you want to go for it, do so. I can borrow a trailer, pick it up & put it behind the shed. I'll get the heater and anything else you want out and post them over.
Sometime I'll try the motor to see if its OK. There looks to be some rust there, but there are bound to be other bits that are useful.
Cheers mate,
Tue Jul 01, 2014 11:33 am
Will do I told the guy 2-3 weeks for pickup, he was happy,
the other thing is are you going to the Nats in Tassie, as im in no hurry you could bring it there.
Tue Jul 01, 2014 11:22 pm
Yeah mate, we most certainly are. And we will have 2 boots, so plenty of space. No worries, if that suits you.
Wed Jul 02, 2014 12:57 pm
Theres that trailer again........
Closer up, OK, its a bit rough, but thats good! Don't feel so bad about parting it out.
Theres a spot behind the shed, but too wet to get to at the minute! This is also a good thing, cause it means water is running into the dam. :D
Heater is intact, as are most things, but the seat, and no jack. 10/74 model, still with G161 and column shifter.
Will it be a goer? Just need a fine day! ;)
Goodonya Josh!
Fri Jul 18, 2014 11:46 am
Having some sunny weather, so I had a play with the Luv. Its a goer!! :D
They always go! ;)
OK, I had to siphon the old fuel out of the tank, (no fuel cap) clean the plugs and prime the carbie.
But then turned the key and its running sweet. No rattles, no smoke, no drama! Tomorrow I might go for a run around the paddock! Spare Florian motor! Yeaaaaaaah! :o
Goodonya Josh!
Tue Aug 05, 2014 12:38 pm
