View unanswered posts | View active topics It is currently Wed Apr 08, 2026 10:55 am
Florian Interior Hanldes
Just wondering is someone out there might have Florian window winder handles and/or interior door opening handles.
To go on a Chev Luv, I know interior door opening handles are the same, not sure about the winder handles?? :D
Tue Jun 17, 2014 2:22 am
Josh . Recon I can help . What do you need exactly . Gricey
Tue Jun 17, 2014 5:07 am
off topic, Gricey, did you get your DOHC engine re build done ?
Tue Jun 17, 2014 6:38 am
That would be amazing, I have attached 2 photos of what is on the Luv.
1 shows the chrome winder handle which i gather is correct just unsure if its the same as a Florian.
Door handles 1 is gone the other the trim is missing and the plastic mounting is broken.
The mechanisms both work fine and open with little effort so me thinks the little Italian Concreter
who owned the car for 41 years was a little rough.
Tue Jun 17, 2014 6:45 am
Josh . Yep sure I can help . I will get them off to morrow . Pm me your address . Gricey
Tue Jun 17, 2014 6:53 am
Glen . Yep motor is all done all I need is the webber manifold . Greg is getting some made . The body still needs some work and it will be ready for paint . Finished car is not planed untill albury Nats . Gricey
Tue Jun 17, 2014 6:57 am
i have some as well if needed, but mine could do with a refinish.
Tue Jun 17, 2014 7:36 am
great. look forward to seeing it.
Tue Jun 17, 2014 9:06 am
On a side note, anyone out there wrecking a Flo have a heater unit to sell.
Or an idea for a solution?? :D
Wed Jun 18, 2014 12:31 am
Will bellett one fit perhaps.
Wed Jun 18, 2014 2:21 am
Thanks Glenn A Bellett heater is fairly different BUT you got me thinking!! :geek:
I have Bellett heaters and plenty of room in the LUV!!
Prob the most difficult part would be the fresh air intake....dont need it! just recirculate.
4 fire wall mounts, I can make up a bracket to mount the heater, reckon enough room to mount it
Bellett style or even vertically.
At least gives me demist and heat till i can find the right unit!!
Thanks for the kick start Glenn
Wed Jun 18, 2014 3:34 am
No problem Josh. I have no idea really, but 'thought' maybe the firewall is similar. Anyway, a Bellett heater is much easier to find than an Elf one.
Good luck with keeping warm.
Wed Jun 18, 2014 5:11 am
Josh, I reckon OzLuvTrucker would have a Luv or at least a KB heater. Perhaps message him in case he hasn't read this. Bellett heaters with fans are hard to find.
Cheers, Matt
Wed Jun 18, 2014 9:56 am
I have a bellett heater electric will do a swap for a set of watanabe mags to suit a gt ...joking .....davo ( ok a new 1600 gt water pump)....???also have the air flow heater model no motor .driving it . I will pull them out tomorrow and have a good look at them
Wed Jun 18, 2014 10:01 am
correct Matt, and i have kept all of the ones from cars i wrecked over the years too...
not all in the one place but may get them together one day for a reunion :) :) :)
and there were 10 Bellett's in my suburban back yard at one point, and a few Florian's too
the kids used to pretend drive them and jump from roof to roof
its a journey of discovery, you just never know what is squirreled away in that shed!
Wed Jun 18, 2014 10:08 am
Thank fellas, forgot ozluv, I already have both faned and non faned Bellett heaters. Gona pull one out and see if I can make it fit as a temp solution!!
Wed Jun 18, 2014 10:37 am
Car(s): 1980KBD40 ISUZU
I have a good heater box and core in the scrub Luv.
Wed Jun 18, 2014 9:10 pm
I appreciate the offer OzLuvTrucker but I dont want to take something out of your car, Im sure
a wreck of a Luv or Florian will come up and in the mean time I will mod a Bellett heater
to give me a demister.
Wed Jun 18, 2014 11:35 pm
8-)
Thu Jun 19, 2014 11:22 am
If you do hear of a Luv for wrecking let me know.
75-80 seems to be the best option for some reason all the 72-74s I have seen don't have heaters.
Thu Jun 19, 2014 11:34 am
