View unanswered posts | View active topics It is currently Thu Apr 09, 2026 11:03 pm
Reply to topic  [ 8 posts ]
White drivers door to suit Bellett sedan
Hi folks, just got back from holidays in Peru - didn't see any Belletts,but just about every other old car ever made.
Has anybody got a white colour ,straight drivers door to suit a Bellett sedan?
(I have a red one to swap if needed).Just the bare door shell is OK ,as I can swap the bits over.
I have a dinged up white one on it at the moment,but is a bit of an eyesore.
i will be at the Nats,so can pick up from there,
thanks,
Rod.
Mon Sep 17, 2012 8:11 am
Gary has some doors down here....Ill ask him
see you at the Nationals :mrgreen:
Tue Sep 18, 2012 9:41 am
Thanks For that Gary,see you there soon!
Wed Sep 19, 2012 12:21 pm
mate if all else fails i have a couple here but no white ones ..just shells ..x woodburn see how you go with gary ..c heers davo
Wed Sep 19, 2012 12:55 pm
Thanks Davo,I will keep it in mind.The Teardrop is coming together.Got the seats all back in today & she starts and runs after 14 years laying idle :D
Still owe you some beers at Merimbula for those door trims :)
Fri Sep 21, 2012 9:28 am
remember to check what model Bellett the door is off before fitting tho...
even tho a sedan door will fit any sedan, they did change where the stainless trim was fitted. i can't remember which model was what, but i know the trim was moved from above the body line to below at some time.
we found this out years ago doing exactly as u are now...
Fri Sep 28, 2012 10:22 pm
Brett, :shock: . Not sure when?? This should be in the quiz...........Change was with the tail lights. Teardrops have curved moulding above the crease, '66.5 hexagon lights and thereafter have pointed moulding below the crease.
One : Nill, mate! :P
Cheers, Matt. ;)
Thu Oct 04, 2012 12:38 pm
Thanks for the info guys - I got 2 white drivers doors on the weekend, 1 early , and 1 late and the stainless trim on the later one is about 15 mm lower than the other .
Thankfully I now know which one to fit to my Teardrop!
Wed Oct 10, 2012 11:13 am
