View unanswered posts | View active topics It is currently Wed Apr 08, 2026 11:02 pm
Reply to topic  [ 15 posts ]
Waterpump off of 72 Luv for use on Bellett's
It has been suggested that a waterpump of a Chevy Luv 1972 could fit onto a Bellett.
The LUV pumps are still available here in the US.
I had a request from oz_toffa who wants to try this out.
I ordered one and took some pictures which I will post here for a comparison.
Most of the bolt holes seem to match up and the actual pump housing is a very similar shape.
The outlet is in a very different place, but I would think a flexible hose would work.
I will leave it up to oz to actually try and fit it on.
I'll see how adept I am at loading up the pictures here.
Doug Hillmer
Sun Aug 19, 2012 11:38 pm
I forgot to mention anything about pricing.
This particular LUV pump I got was about US$32 (24 plus 8 for shipping to US address).
We have not yet ventured to see how much it is going to be to ship over the pond, but I suspect around as much as the thing cost.
Doug Hillmer
Sun Aug 19, 2012 11:47 pm
This is both pumps side by side
File comment: Both pumps side by side
Doug Hillmer
Sun Aug 19, 2012 11:49 pm
This is a closer up of the original Bellett pump.
One thing to note is that between holes 2 and 3 in the picture there is another hole.
On my engine there is no bolt in that hole. I mention this because on the LUV pump (next picture) there is no hole there.
File comment: Original pump off 65 Bellett
Doug Hillmer
Sun Aug 19, 2012 11:52 pm
Here is the LUV pump. (Bomba de LUV in spanish, has a nice sound to it :)
Note the direction of the outlet.
Also note that hole 1 does not exist.
That may be the real sticky point, but I think it could fit still.
File comment: New pump for 72 LUV
Doug Hillmer
Sun Aug 19, 2012 11:54 pm
One last picture here, there was a gasket that came with the new one.
I scanned a copy of it and hopefully this will come out as actual size
(print on 8.5x11 paper).
File comment: New LUV gasket
Doug Hillmer
Sun Aug 19, 2012 11:58 pm
I have a chev LUV water pump also here (at home that is) but it has a boss on the back area of the water outlet i think. Can't recall if Bellett has that also.?
Mon Aug 20, 2012 12:16 am
I had realized I also should have taken pictures of the backside.
While Glenn was busy replying, I was doing that.
Yes there is a hole in the backside of the outlet that would need to be plugged.
I suspect you could find or make something to screw in that would plug it.
(see pictures to follow).
Doug Hillmer
Mon Aug 20, 2012 12:22 am
Here is the backside of the original Bellett pump.
File comment: Backside of original Bellett pump
Doug Hillmer
Mon Aug 20, 2012 12:23 am
Here is the backside of the LUV pump, notice it has a plate screwed on.
File comment: Backside of LUV pump with plate
Doug Hillmer
Mon Aug 20, 2012 12:24 am
This is the backside of the LUV pump with the plate removed.
File comment: Backside of lUV with plate removed
Doug Hillmer
Mon Aug 20, 2012 12:25 am
Looks like 1800 sohc water pump to me :?:
Mon Aug 20, 2012 9:15 am
ala Chev Luv. I bought one the same recently off ebay.
Mon Aug 20, 2012 9:49 am
thanks for all your help there, Doug.
may be able to use internal bearings and seals to repair the original Bellett pumps.
worth it for a job lot.
cheers
Mon Aug 20, 2012 10:49 am
That was the pump I was looking at for the OHC motor sitting in the shed Oz.
Maybe I'll have to owe you money for two pumps :shock:
Thu Aug 23, 2012 10:06 am
