View unanswered posts | View active topics It is currently Fri Apr 10, 2026 11:56 pm
Fuel filter bellett
To day while dumping a non payer I found 2 new filters that appear to fit bellett . Can anyone clarify for me please. Ryco r2224p many thanks . Gricey
Tue Jul 03, 2012 6:04 am
a search on r2224p here brings up a few things....
http://www.bellett.net/forums/search.php?keywords=r2224p&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
I have been pasting anything useful looking from these thgreads into a spreadsheet...... here is my info:
Bellett fuel filter:
Ryco # R2224P. No longer made.
We believe there is a geniune Nissan filter that fits this. Does any forum member know this part number??
Ryco # R2058P. Not known if still made. Thanks to "65bellett" for this #.
see bellett.net for using a common fuel filter in plastic housing (P/N "SC4F"), cut it open and use the filter inside
is the type with pipe exiting each end
see the thread "FUEL FILTER RYCO ORIGINAL R 2224P"
RANG RYCO TODAY NO LUCK ON ANY GENUINE R2224P ORIGINAL FUEL FILTER WENT TO SUPER CHEAP BOUGHT THE PLASTIC FUEL FILTER
$2.99 HAD A LOOK AND THOUGHT GEEZ THATS CLOSE SO TOOK IT HOME CUT THE LID OF AND ITS VIRTUALLY A PERFECT MATCH
UNSCREWED THE FILTER PUSHED IN THE NEW YOU BEAUT FROM SUPER CHEAP ...AND AWAY WE GO ....SO WENT BACK AND BOUGHT A SPARE ...HANG THE EXPENSE ....CHEERS DAVO
hi brett part no. SC4F BARCODE 9323129007028 CHEERS DAVO
Tue Jul 03, 2012 6:08 am
Gricey,
I am more interested in what else you might have found...............
Tue Jul 03, 2012 6:37 am
Hey Gricey just check to make sure you had the right container, and it wasn't your container :o and keep looking might be another GT or something there. :?
Tue Jul 03, 2012 7:08 am
Also found a carton of new oil filters. Inch drive socket set. Set of coil spring compressors . Amongst outer bits . I love this business . Suck s-------t gricey
Tue Jul 03, 2012 8:41 am
That's not nice :o
Tue Jul 03, 2012 8:58 am
