View unanswered posts | View active topics It is currently Fri Apr 10, 2026 1:59 am
Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
Removing window winders & door handles
no room is rite....
wait till u start modifying them and shoving all sorts of hardware in there tho....
Tue May 22, 2012 10:26 am
Thanks guys,I managed to get the winder and door handle off today. They can be a bugger to force the spring loaded winder handle ring back to get to the pin. Looks like my plastic washer that's against the door trim has shrunk ,and the ring won't slide back into the small centre hole.finally got them off.
Found all the window frame bolts and it slid right out! New window now fitted and all back together.
Haven't put the handles back on yet,as I am thinking of making the plastic washer centre holes slightly bigger,so the spring loaded ring works properly,as I am sure I will one day have to take them off again,
Cheers,Rod.
Sun May 27, 2012 10:47 am
MATE YOU WANT THE ROUND PLASTIC WASHERS THAT GO ON THE TRIM THEN THE CHROME CIRCLE I HAVE A SWAG OF THEM IM BUSY THIS WEEK BUT NEXT WEEK IM FREE AND WILL ORGANIZE ..HOW MANY DO YOU WANT AND THEN 3 DOOR TRIMS CHEERS DAVO KEEP AT IT
Sun May 27, 2012 10:55 am
Hi Davo,I might get 4 of the plastic washers and 4 of the chrome rings if you have them as spares.Maybe yours haven't shrunk ,or whatever has happened to mine.It could even be the chrome pitting on the rings that won't let them slide into the washer. Next week would be great ,thanks mate,Rod.
Sun May 27, 2012 11:16 pm
no problems ..will organize 4x4 rings cheers davo
Mon May 28, 2012 2:55 am
hey rod just went into the stash ok for 6 good ones ..do you want some door pulls with chrome heads /? cheers davo
Mon May 28, 2012 6:23 am
Hi Davo,I am right for the door pulls.They are a bit faded like most I suppose,but all in good nick,and I have a few for spares ,thanks.
Mon May 28, 2012 8:29 am
