View unanswered posts | View active topics It is currently Thu Apr 09, 2026 4:35 pm
Reply to topic  [ 15 posts ]
kempsey hillclimb
I had the opportunity to use fast64s in car cam after his group n car had a engine failure :oops: We could not see the piston but you could see the dents in the sump where it tried to come out :? .
Glenn was offered the use of my car to see if he could blow it up as well :oops: after all he own's the engine in my car anyway. It was a lot of fun and a little more of a challange to have someone with years of experience to run against in the same car i am usually around 2-3 seconds behind him and only being new to the sport i was happy with this. But in the same car we were under a second apart. I have to factor he was getting used to the car but my bellett is a clone of his in most ways.
http://www.youtube.com/watch?v=C9FImUsr ... e=youtu.be
Tue Apr 17, 2012 3:40 am
bloody great stuff... nice little teardrop ...and nice ashtray cheers davo
Tue Apr 17, 2012 4:39 am
i think you got your ash tray and toolkit would be my guess :?:
Tue Apr 17, 2012 5:34 am
some people have all the cheek and the hide the size of Myers..
but good luck to ya if you can convince the owner to parts the car out. Even if it halves the value?
Tue Apr 17, 2012 12:18 pm
Oz. Seems to me that the price is realY above what it's worth any . So davo got the best deal . Good one davo. Gricey
Tue Apr 17, 2012 8:38 pm
I only assumed Davo got them but both items were on his wish list :?:
Wed Apr 18, 2012 3:03 am
EXACTLY GREG THEY WERE ON MY WISH LIST WHICH IS ALL BUT NOW COMPLETE .,,,,, I PUT IT OUT THERE TO GET THE CAR ...I GOT IT ....I PUT IT OUT THERE FOR AN ASHTRAY AND ...OK A TOOLBAG ...I GOT IT ...I WENT ABOUT IT A DIFFERENT WAY I GUESS ..BUT ITS MEANT TO BE ...INCIDENTALLY I MIGHT LOOK AT THE CAR TOMORROW ...CHEERS DAVO
Wed Apr 18, 2012 6:01 am
Car(s): 65 and 66 sedan
Awesome video!!! What gear box are you running as you did not seem to have a big gap between 2nd and 3rd??? Now to go and find your build thread and drool for the rest of the night.
Mon Apr 23, 2012 8:35 am
gear box is a later syncro box stack as far as i know :?: the car was built when it got to my hands. the only thing i did was made a reverse lockout so i can't pull R :shock: instead of 2nd :oops:.
other builds are a little slow patches is very close to done off to the trim shop next week for carpets and door trims i got the seats back today i will send picks.
ol yella is sleeping in the spraybooth tonight :D
Mon Apr 23, 2012 8:46 am
Might hafta lift ya sights ol mate! The bid is the evidence. (Don't forget, you gotta beat the crusher price!)
The broth was in the area & had a look - almost zero rust, complete but for ashtray & toolkit :!:, chrome pretty good, good compression...... Swap a door & guard & it's better than it looks.
But he's not the buyer.
Anybody we know?
Cheers, Matt
Mon Apr 23, 2012 11:29 am
what was the final bid :?:
Tue Apr 24, 2012 6:19 pm
Gt Orphanage any chance of a couple of pics of your reverse lock out. I will normally let any body have a drive of my car at an event but some times regret it when I hear them go to grab reverse into a corner (and may be I may have done it my self a couple of times :oops: ).
Wed Apr 25, 2012 12:11 am
Gav it's easy to make.
take the gear stick out 2 bolts then the next lot 4 bolts of the box, now the 2 bolt flange weld a plate to the side of the flange that sits over the detent for reverse, now take the big nut of the end on the detent case the spring will want to come out let it then the pin you can see down the hole push the pin in hard and mark it drill a hole so if you put a rod in the hole the pin cant come back this will stop the stick coming back. The round rod thickness mine are around 4mm so a mmhole was drilled put the spring and bolt back in place.
Put the rod down the hole it will hit the spring only in a couple of mm put a flat washer over the rod and let it sit on the alloy housing and tack it to the rod, all done. reassemble the 4 bolt to the gearbox and the stick a hole needs to be drilled inline with the hole in the housing now put a compression spring over the rod between the plate and washer now put he stick back in.
i will put photo's on in a little while this sounds hard :lol: but it's 1 hrs to do it.
Wed Apr 25, 2012 6:47 am
here are some picks
Wed Apr 25, 2012 7:01 am
That is very very clever. It is not some thing I had ever thought about doing until you mentioned it. When I pull the heater out and get the rubber matt out of the front I will do it. Cheers
Wed Apr 25, 2012 2:25 pm
