View unanswered posts | View active topics It is currently Sun Apr 12, 2026 8:42 am
Reply to topic  [ 11 posts ]
Water PUmps
Not sure if this is a bellett water pump as it's while since i lookd at one.
http://www.importmonster.com.au/view?ur ... le=BELLETT PR10 PR30 PR50 Jntj
Fri Feb 24, 2012 1:40 am
They are cheaper out of the US
Fri Feb 24, 2012 4:43 am
sure is Bellett. But depends on postage.
waterpumpwarehouse.com are just under $100AU inc postage
Fri Feb 24, 2012 8:47 am
Isabel,
Do you have any contact info for one out of the US?
I am interested to know pricing.
Thanks,
Doug Hillmer
Fri Feb 24, 2012 5:02 pm
Doug go to ebay usa and they are listed from a company called The waterpump wharehouse they are for a g150 forlift. They fit 5 bearing no problms but the three bearing you need to remove the rear plate and inside is a bypass that i had to block to stop it from leaking.
Fri Feb 24, 2012 10:12 pm
waterpump needs to be a G150. go to www.waterpumpwarehouse.com and search for isuzu G150
postage was about $40 and pump about $69
currently showing out of stock :(
Fri Feb 24, 2012 10:32 pm
The one on Import monster, if you put in the calculations to buy and deliver for you will be over $200. they have a $30 service fee plus their freight is very expensive. :(
Geoff.
But the good thing is they are still being made. :D
Fri Feb 24, 2012 11:49 pm
Silverline pump CP0319. Or CP319 in other brands. Try your Bursons/Repco/Auto aftermarket suppliers.
Contents. GMB waterpump GWIS-13A. Bought last one in Ipswich about 3 year ago. Walkers Auto.
Now on my sedan.
I did also buy one from Thailand, a GMB unit, $95 Aus. incl. postage. 1 for the Wasp. It has a 5 brg. in it.
About 10 years ago I got the GM Holden dealer to get me 1. Genuine @ about $145.00.
Part number. GM 94021875, Isu 9136102730.
Hope this will help.
Sat Feb 25, 2012 8:12 am
Doug.
I did not realize untill after I posted my reply that your question was for a supplier in the US. Sorry.
Unless someone had imported them into the States in a big way by accident, the only option is as suggested
is by buying outside through Thailand,Japan etc.
Google or Yahoo automotive waterpumps or Isuzu waterpumps. Another is GMB(Japan), who is the largest manufacturer/supplier to Australia in aftermarket, and marketed under different brand names. You may get lucky.
This pump fits a multitude of Isuzu engines of this era. ie. 1960's- early 70's. Faster Kb20, Florian Pa10, Elf150 KA40,
Bellett PR20-66.5 on. 5 brg crank. All overhead valve, cam in block. Not overhead cam, as in the Chevy Luv.
Sat Feb 25, 2012 8:49 am
Dave,
Thanks for the note. The reason I asked about the US was that Isabel had said they would be cheaper in the US and I was surprised to read that. As you said, I doubt they were imported here. However in looking around it looks like the same pump for the PR20 fit a bunch of other stuff as well.
Doug Hillmer
Mon Feb 27, 2012 12:11 am
Car(s): 65 and 66 sedan
Last year I picked up two ex Singapore for about $140 us. Get em while you can folks!!!
Tue Feb 28, 2012 12:05 am
