View unanswered posts | View active topics It is currently Wed Apr 08, 2026 7:42 am
Reply to topic  [ 127 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
Alistairs 1970 Bellett 1500
Exterior is stripped now, just engine to take out and she can head off for panel/paint.
As you can see from the pic above, I will need some new bits.
If anyone can help....Im looking for good-verygood cond:
Tail Lights
Rear license plate lights
Front bar Indicators
2 x Bellett Guard Badges
1 x Front bumper rubber bumper strip. (They have 2 im missing one)
Mon Nov 10, 2008 7:02 am
Eeep those front blinker lights are basically unavailable here in Australia as we basically didn't get your model (there were literally less than 10 brought out here I'd guess and they're probably all in Tasmania!). Have you tried Dik in Holland? He can be found on the Web if you do a Bellett search.
Mon Nov 10, 2008 1:44 pm
Thanks Dave have emailed Dick, will see what comes of it :)
Mon Nov 10, 2008 6:32 pm
Engine is out, just needs degrease and water blast in engine bay (and removal of all the shit like horns, fluid bag etc) and it is going to my mates workshop in the weekend and I wont have it back until the new year in its fresh white paint :D Will update periodically as it goes through welding, patching and primering stz. Nice thought to know I dont have to touch it for 2 months!
Note newly discovered hole in chasis rail lol! Will have to have that patched along with the sills and shizz.
Wed Nov 12, 2008 2:18 am
Whoah that's a fair-sized hole! Thanks for all the updates; it's been good to follow the progress of this car for the short time you've had it.
Wed Nov 12, 2008 3:05 am
The joys of old cars I guess!
Wed Nov 12, 2008 3:06 am
Bugger about the chassis rail hole :( I think we've all had to deal with rust down there at some point though!
Can't wait to see her in the new year, all nice and sparkly. Thanks for the updated pics :)
R.
Wed Nov 12, 2008 3:09 am
Last lot of pics cause I can.
So now I can play with making the chrome bits nice and degreasing and cleaning the motor while the body is seen to :)
Wed Nov 12, 2008 5:53 am
Car(s): 65 and 66 sedan
You are a man of action Alistair. Can't wait to see the next set of Pic's.
Wed Nov 12, 2008 6:33 am
These are some older pics of passenger side sill i forgot to post
Sat Dec 13, 2008 12:13 am
New pics of drivers side sill/guard work and also the beginning of me undersealing the old girl. I freakin hate that shit!
More tomorrow :)
Sat Dec 13, 2008 12:20 am
Hi Alistair, great work, keep going. Looking at the photo's of the rear transleaf spring it appears to be installed upside down, if my memory is correct to w plate should be to the top and locates with a rubber shaped the same, this may reduce the pos camber a little. Prior to me obtaining a factory competition transleaf, we use to have two, sometimes three transleaf springs clamped together, hard to describe though they started with the spring tensions oppisite each other and then clamped, then for a little more neg , we would place either another larger rubber between the leaf and the wishbone mount, or if this was too much, one of the smaller rubbers, these little adjustments are dependent on driving and or road conditions, if i get a chance I will post a photo of the factory rear transleaf, regards Geoff.
Sun Dec 14, 2008 7:35 pm
Would be great if you did have some pictures, I had a thought that it may be installed upside down when I was first looking at the camber issue.
Mon Dec 15, 2008 4:23 am
Hi Alistair, attached are photo's of the factory rear transverse spring, its a little grubby under at the moment, as you can see they have 4 leafs set at progressive lengths with the lower leafs ends curved slightley upwards, this set up also uses smaller diameter coils ( Isuzu racing ) unsure of their poundage with Isuzu racing shocks
Tue Dec 16, 2008 8:40 pm
A couple more
Tue Dec 16, 2008 8:42 pm
The sedan only has the one leaf spring from the factory unless it's the race trim one.
I'll get a picture from my '69 sedan for comparison and then it might be worth moving this discussion to the Tech section as it's going off topic a bit :)
Good pics of the multiple leaf rear though pearcesnr. Do you have a photo to show how the car sits at the rear with that setup?
R.
Wed Dec 17, 2008 12:12 am
Rear is set at around 3 degrees neg, i do not have shot from behind. this is the best on hand :cry:
Wed Dec 17, 2008 12:48 am
Sits nice under load, uses all of the 255mm of rubber ;)
Wed Dec 17, 2008 12:59 am
Bit more of an update on panel work before primer on monday :)
No more chasiss hole!
There we are, might do a bit more tomorrow. Like how the crossmember came out, much tidier.
Sat Dec 20, 2008 1:25 am
Coming along nicely! You are definitely a man of action :)
Good luck with the spray job! What colour are you going for?
Sat Dec 20, 2008 1:48 pm
