View unanswered posts | View active topics It is currently Wed Apr 08, 2026 2:05 pm
Reply to topic  [ 40 posts ]  Go to page Previous  1, 2
bellett on gumtree adelaide
congrats on the savvy buy! i cant wait to see it in the flesh! there is slowly being a mob of belletts built up here in SA!
Tue Aug 09, 2011 1:18 pm
ok just a little tease
Tue Aug 09, 2011 1:20 pm
score 8-) and in good hands well done.
Tue Aug 09, 2011 3:39 pm
great stuff gone to the right home ..and the grin ..mate its equally as big as bemboka gary .. nice little car cheers davo
Tue Aug 09, 2011 10:19 pm
the journey starts...
why oh why oh why do people leave the air cleaner cover off and the bonnet open?
ok i know it was in a shed but sharing with all the birds
never seen a carbie so full of crap
just makes you want to cry
Wed Aug 10, 2011 10:30 am
bugger! that sucks!
Wed Aug 10, 2011 10:40 am
to be more accurate, it didnt at all!!
after it was removed, blown out with air, sprayed out with good quality de-greaser and washed with the jet nozzle of hose and given a good drying it looked a lot better.
didnt even know if the engine would turn over, so the bores got a good spray WD-40 and couple of squirts of engine oil down each plug hole, left to soak for 30 min and she turned over with a spanner on the crank really well
so in went the new plugs, coil got re connected the correct way around, engine oil looks real clean and i even connected up a charged up battery and gave it a burst or 2. needs some fresh petrol and replacing of the non genuine starter solenoid with a Isuzu one.
needs quite a bit of work in the engine bay and some rust treatment to stop some surface rust around the battery casing but no real bad rusting of the tower or inner guard.
more as it comes
Wed Aug 10, 2011 12:15 pm
nice oz! i will be down to check it out soon!
Wed Aug 10, 2011 12:58 pm
Good onya, Oz! Under 2 grand? Baaaaarrgain! ;)
I'm glad you were able to get it, and at Mrs Oz's suggestion, maaaaate!
48,000 m's is probable with that condition - pretty nice.
I reckon if there's enough compression to push your thumb out of the plug holes, it'll run. Might be a bit smokey till it burns the oil out. Make sure the separator & hoses are clear & clean or it can make a motor seem a lot worse. (Aunty Mary's were chocka with crud, even the fittings on the block were blocked tight. Opening them up let her breathe, so there was a lot less sump pressure at the oilcap.)
Look forward to reading more,
Cheers, Matt. :D
Wed Aug 10, 2011 1:26 pm
Good buy!
Thu Aug 11, 2011 12:03 am
great work!..... :D
Thu Aug 11, 2011 1:10 am
Nice one Chris, I vividly remember that yard full of Belletts 20 years ago, I can only imagine it now! :)
Hope you don't find your bores full of budgies.
Have fun mate.
Duane
Thu Aug 11, 2011 1:31 am
the adventure continues...
the carbi looks a lot better??
and these wheels trims are just super. wait till i polish them
brakes need checking and bleeding
rust in the battery area not really too bad at all
and the sun sets on another busy day down at the shed
have managed to get the motor to run for a short period of time and now know why the previous owner thought it would need some work and maybe a re-build.
Oil pressure is not coming up to par and she has a bottom end rattle!!!
it will be coming out in the next week or two and the crank will have some machining repairs done and new bearings etc fitted.
reckon compression is still real good so not likely to remove the head or pistons at this stage.
radiator was rod cleaned and i wont get another go as its very thin but it was 85% blocked.
reckon with brakes, engine bottom end, cooling system sorted and tune etc it will cost me another $500 on the purchase price. Not too bad for under $2500. but engine could be a money pit :(
Sat Aug 13, 2011 1:43 pm
Congrats OZ. Great score, and auto too.
Sun Aug 14, 2011 12:49 am
Absolute.................BARGAIN!
Looks so nice - good buying.
Wed Aug 17, 2011 11:12 am
the journey continues...
bought a new Engine Crane and Load Leveler to assist the engine repair
nice bit of kit. just one problem. the extended base legs don't fit under a Bellett front end!! i reckon they would not fit under most Japanese 4 cylinder cars so one front wheel has to be removed and the car jacked on that side.
long story short the engine is out and will very soon have the crank removed and away for repair.
sure hope there is not too much damage down there?
also found a bit more rust then i first thought but that's all part of the fun
Wed Aug 17, 2011 11:27 am
Geez that auto is super-tidy. Good buy; this explains where the new avatar came from!
Sorry for the non-response re: the trailer (this thread explains the need) but Ross told me you had got in touch with him so I didn't follow it up.
Sorry for being a slacker! Will get rego on it again soon...
Sun Aug 21, 2011 4:35 am
now we are getting to the bottom of the problem
Big end Bearings are not looking happy
another day finishes in Adelaide's Best home workshop
Tue Aug 23, 2011 10:20 am
Car(s): GT.
Oz,
If you have a problem obtaining the bearings, we might be able to assist you here in Sydney, dependant on the size you are requiring?
You can certainly see why the littler hammers were out when you started the motor!!! WOW.
I wonder why that happened, low oil, not serviced regularly, ??????
What was the condition of the oil filter? Might give you an indication.
Tue Aug 23, 2011 10:25 pm
its real hard to say, but the car was a town run about and taken on occasional trips so it may have run low on a country run. Also the oil was pretty runny, not quite like water but still thin. May have fuel pump leak back into the sump or even an issue with oil pump pressure relief.
i will be doing a number of tests with no ignition and no plugs to pinpoint the cause once the crank is repaired.
also have some sets of Big and and Main bearings on way over from the US. .25mm and .50mm for the Big end and standard for the mains.
once i know what i am looking at i may well come back for some assistance in finding the right stuff. Thanks for the offer :)
Wed Aug 24, 2011 12:34 pm
Users browsing this forum: No registered users and 61 guests
