View unanswered posts | View active topics It is currently Tue Apr 07, 2026 11:17 pm
Temp Sender Unit/Oil Pressure switch
Temp Sender Unit, Oil Pressure switch/sender and thermostat.
Does anybody have part numbers or brand names for these items to suit my PR90. It looks like they all use the same item in the G150/G161 so I am assuming the G160 would be the same but I do not know who makes or supplies replacement items
Regards
Tue Mar 08, 2022 6:58 am
Hi Peter,
I don’t know the part numbers, but Bursons do have listings for the thermostat. Trident brand I think.
As for the sender switch, I would take the old one in to them to get matched up. Assuming you have the original?
If your local doesn’t list Bellett or Florian, get them to try Chev Luv.
Tue Mar 08, 2022 7:18 pm
Hi
Not sure but my notes read……
- Oil sender for GT
The part is a Sankei part made in Japan to work with Yazaki gauges
Sankei Part No, KG-812 83520 55011, it is to suit Toyota Hi Lux around the 1990's diesel engine.
- Thermostat 71'c Trident TT1 -160
Stant ST 1-160 71'c
- Temp sender Champion CTS139 M16x1.5 / Tridon TTS066
Hope this helps
Wed Mar 09, 2022 9:09 pm
Thanks for all your help here guys. What I did not realise was that the GT had two oil sensors/switches. (Duuuh)When I got the car there was a switch at the bottom of the oil pump and nothing else I have just had a look at the wiring diagram and a poke around a have found the hole at the rear bottom of the block for the other sensor. This now make sense as I could not see one item doing two functions eg, oil dash light and oil gauge. It looks like the Tridon TPS 006 will do the switch at the bottom of the oil pump and the other one you mentioned will do the gauge.
As you have mentioned the temp sender unit TTS066 will do the job for the temp gauge and you have also provided info for the thermostat.
Looks like I am all sorted thanks to you lot.
Regards
Thu Mar 10, 2022 8:29 am
