View unanswered posts | View active topics It is currently Wed Apr 08, 2026 9:07 am
Reply to topic  [ 137 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
69 Deluxe Sedan
Thanks, I have news...
Got the bonnet out of the shed to fix and got the flat tyre off the the front... I really should have fixed that went it went flat... Think the side walls are stuffed.... But then again I think the tyres are 20 yrs old... So should be replaced...
Little bit at a time but... Work has started again on it...
Cheers Chris
Fri Jan 09, 2015 1:25 pm
Having the wheel off means I can take a good picture of the front brakes, XF discs and RX7 series 4 calipers.
Sat Jan 10, 2015 1:26 am
....smick............
Sat Jan 10, 2015 1:48 am
that should stop it !
I see re-drilled disks..... not allowed here in Vic.. Is it ok up in NT ?
Sat Jan 10, 2015 8:03 am
fussy bastards in Victoria in qld all you need is a lead weight and a rope...ha ha
Sat Jan 10, 2015 8:51 am
I thought you just dragged your feet on the road up there Dave..... out thru a rusty floor ;)
Sat Jan 10, 2015 10:02 pm
very goog I like it glenn ...
Sat Jan 10, 2015 11:15 pm
They'd have to take a wheel off to notice. Not too many places would do that in newsouth!
Looks pretty sound, and a fair improvement on what is required.
Sun Jan 11, 2015 10:56 am
I um'd and R'd over getting blanks drilled... Just wanted to get the setup all done before I went to that expense...
Wheel fixed so should be able to pull it out of the shed this weekend... About time it's been a while... Looking a bit dusty at the moment... Binet goes tomorrow to the boys at Delta to get sorted.
Slowly working on the exhaust down pipe...
Cheers Chris
Mon Jan 12, 2015 3:46 am
Chris
Looks great
Hopefully see you for Jap Day in March?
Dave mentioned that the Bellett's may get the centre spot the more the merrier.
Flying
Mon Jan 12, 2015 7:46 am
keep it going chris, along with the photos please...
we re all lovin watching the progress and AJP is on the way.
Tue Jan 13, 2015 9:51 am
Hi,
Slowly but surely the exhaust is happening... :-) AAA Exhausts have been awesome in helping out with tacking the bends as I bring them in. Here are a couple of pictures so far.... Still a bit to go though.
Wed Feb 04, 2015 8:06 am
VERY nice work. Not a lot of space under a Bellett for bigger pipes, mufflers etc.
Wed Feb 04, 2015 8:09 am
Chris, that exhaust is lookin just superb, comin along really well!
keep it going
Sat Feb 07, 2015 2:21 am
A long time ago, I got the wrong light mount, blasted and painted... just wondering if someone may have the right ones...
Sat Jun 30, 2018 11:18 pm
Is the picture the one you want ?
Sat Jun 30, 2018 11:44 pm
I threw the ones that were on the car away, think there from a PR90 I need some from a PR91....
Sat Jun 30, 2018 11:49 pm
Hello Chris.
Knowing which ones you need is a bit difficult. I have some here of various types. PR90 is early GT single headlight. PR91 is single as well until '68 1/2 where they changed to strip taillights and twin headlight. Sedans changed with grille changes. If you post a pic of the grille and light surrounds you intend using that will help identify the ones you want.
I'll help if possible.
Mon Jul 02, 2018 9:34 pm
The ones you have are early (teardrop taillight) PR20 sedan. The location of the surround mounts is obvious.
You need the late PR20 mounts that have the surround mounts between the lights themselves.
Tue Jul 03, 2018 1:01 pm
Hi, here is a pic of the original grill I want to use, just would like to st least try to get a set of the headlight mounts, really wish I’d looked but 20 yrs ago when I took the thing off... I really didn’t think... twin lights... twin lights... should be the same...
Wed Jul 04, 2018 10:37 am
