View unanswered posts | View active topics It is currently Sat Apr 04, 2026 9:48 pm
Super cheap spark plugs.
Hi all, not sure if a BCP6ES spark plug could be used on a Bellett but they are currently on 'special' at Repco for just 20c each.
https://www.repco.com.au/en/parts-service/ignition/spark-plugs/ngk-standard-spark-plug-bcp6es/p/A7636598?kwSearch=bcp6es
Mon Dec 05, 2022 6:08 am
Nice idea mate, but normal Bellett plug is BP6ES. The BC denotes 14mm thread instead of 18mm. Would be a bit loose!
Thanks anyway,
Mon Dec 05, 2022 8:11 pm
BP6ES plug. B= 14.0mm thread. P= Projecting insulator type. 6= Heat range. E= 19.0mm Thread length. S= Standard type.
BCP6ES plug. BC= 14.0mm thread with copper core electrode. The rest of the part number is identical to above.
BPR6ES plug. BP. As above in description. R= Resistor type. The rest is identical to BP6ES.
I have used both BP6ES and BPR6ES. No problems.
Tue Dec 06, 2022 12:20 pm
Thanks for the info guys.
Wed Dec 07, 2022 5:45 am
