View unanswered posts | View active topics It is currently Thu Apr 09, 2026 4:37 pm
Reply to topic  [ 20 posts ]
Chrome Wheel Rims
Car(s): Isuzu Bellett sedan 1967
Looking for one chrome wheel rim (see pic) for 67 Bellett as one came off and gone :cry:
Maybe after market or extra fitting available at purchase. Anyone know :?:
I need the chrome rim as well as the 6 holding clips (see pic). Note it also has special cut for tyre valve.
1967 Bellett Sedan
Wed Feb 06, 2013 3:22 am
gday Marvo, and welcome.
they are definitly aftermarket.
Bellett's never had chrome dress rings from the factory.
"standard" sedans like yours had just the chrome hub caps you already have.
"deluxe" sedans had a full cover cap. rare these days.
and GT's had a different full cover cap. VERY rare now!
get into autobarn, super cheap, one of those places for a some new ones. $20 should get u a set of 4 newies.
Thu Feb 07, 2013 12:06 am
marvo check on ebay theres a set practically identical to your 3 in canberra he wants the crown jewels but they are not the k mart plasic models with the wash off chrome item 130842823860 $60 plus pot he may bust then again for virtually same $$ you can get a set of mags ..cheers davo oh sorry one day to go
Thu Feb 07, 2013 8:23 pm
marvo sorry mate those other ones were too dear heres 25 dress rims for $10 there must be a set amongst these or one to suit you item 181074007331 in gisborne victoria oh by the way 14hrs to go all the best davo
Thu Feb 07, 2013 8:58 pm
Where would I get a set of mag wheels?
Might be the way to go and look smarter and handle better.
cheers
Mark
1967 Bellett Sedan
Fri Feb 08, 2013 12:26 am
depends on whether u want new or old style? and what size? both in diameter and width...
new is obvious but old will mean ebay, swap meets, etc.
but remember that even tho they're 4 stud and the same pattern as Datsun, Toyota, etc, the offset is very different and alot won't fit under the guards...
work out what u want and we'll set u on the rite path.
Fri Feb 08, 2013 12:45 am
Hi Mark
For what it's worth, this is the set of mag style wheels that came on my car, and interesting enough they are from a 67-69ish Toyota Corolla, and I got the chrome trim rings on ebay.
Regards
Mark
Fri Feb 08, 2013 12:53 am
Mag wheel offsets for Bellett,
5"-5.5" wide +10 offset
6"-6.5" wide +15 offset
7" wide +25 offset
8" wide +35 offset (will fit with max 205 tyre width and slight guard massage - VERY tight fit)
Any 'FACTORY' mags off Datsun 1200, 180B ,200B, Bluebird or Stanza will fit sweet as, but Datsun 1600, 240K, 240Z, 260Z and 280Z mags will need to be a max of 6" wide (6.5" wide will be hit and miss depending on which year model), some aftermarket mags for 1600 and 240K can be as wide as 7" but the offset needs to be between +20 @ +27.
Any 'AFTERMARKET' rims will need to have the offsets as above to eliminate fitment hassle, with that in mind it will also depend on the ride height of your car. If your car sits as low in the 'ass' as Donkey does atm and your running a tyre size of 205 then you'll get a bit of tyre rub on the inner arch when suspension is under full load in corners so if you stick to a 185-195 you'll be right.
Fri Feb 08, 2013 6:35 am
Stickman & Davo,
Thanks for all the advice found 4 mags 13" x 7 paid $100 for with tyres full tread but yet to see if they fit. Looks to me they are too wide for the 4 studs unless I can get longer studs to replace the originals. The depth of the wheels at the hub is around 28mm where bolt comes through.
Seem to be 114.3 offset. Tyres 185/65R13 84H
Any ideas? 8-)
Mark
1967 Bellett Sedan
Fri Mar 01, 2013 1:18 am
Hi Marvo
They look like Magnum Hotwires very similar to what I had on my GT
The Mag nuts for these rims are a long collar type and meet the studs -- no need for longer ones
have a look on the inside of the rims it should have the offset stamped on it somewhere between 19 - 24?
Flying
Fri Mar 01, 2013 11:43 am
Hi Flying
Thanks for the response. It is great to get some help on this as I am in the dark...... :?
Sorry but the back of each Mag is pretty dirty so where would I find the offset stamp hopefully somewhere between 19-24? If that is all good where do I get the Mag nuts for these rims with a long collar type to meet the studs? I can see that the holes are larger than normal so they would need a long collar type to work.
cheers
Mark
1967 Bellett Sedan
Fri Mar 01, 2013 12:27 pm
hey mark well done .....bit of a clean up and away we go the nuts ...are a tapered shaft i will take a photo tomorrow and post it see if i have a spare nut (not me) for the car i had the hotwires last week today i tried some hyundai late model mags they were14s a bit tight like qurter an inch nuts lined up but on the back too tight ..i thought orphanage fitted some hyundai..??? cheers davo
Fri Mar 01, 2013 3:27 pm
i did Davo of a excel they was free :D
Fri Mar 01, 2013 8:57 pm
hry greg were they like these these are pretty mint asking $150 SET too much but they may barter these are from a place on the coast that wrecks cars they have various sets come and go ...also marvo a shot of the tapered nuts needed for those mags of yours or most in the design cheers davo ...anyone want the mags ??email me
Sun Mar 03, 2013 3:32 am
Those wheel nuts are available from Super Cheap, $15 pack of four 12x1.25 thread, will have to make sure that washers have a taper to match wheel.
Have you had those hy and dry wheels on your car Davo? May need spacers.
Cheers Geoff.
Sun Mar 03, 2013 3:56 am
hi geoff put them on they were a bit tight reckon like you said spacers .....anyone want em they fo back tomorrow cheers davo
Sun Mar 03, 2013 5:19 am
Davo. Geoff could be right in the pitch of the thread that he has had , but all the studs that I have got are 1.5 thread pitch.
Hyundai and Toyota are same. Nissan and some Fords run 1.25. Supercheap up here only keep at the moment 1.25. Have been trying to get some for the set of mags that you gave me and I'm willing to wait.
Mark. There are different depths for the wheel nuts. Make sure that they are not too short as they may "bottom out" and don't actually lock the wheel securely. And. Must use washers on that type of mag.
Sun Mar 03, 2013 1:10 pm
Hi Dave CQ,
You are right, they are 12 x 1.5, I should check my facts, Had to replace one on the caravan while away, at Christmas, and it was 1.25, and I think it has Falcon Mags on it.
With all this bloody rain my brain has gone rusty. Will go back into hibernation.
cheers Geoff :D
Sun Mar 03, 2013 9:20 pm
I reckon those Hyundai rims would look brilliant on a Bellett!! 8-)
Mon Mar 04, 2013 5:33 am
mate they would look fantastic ,they have another set alloy instead of the gunmetal black ....not as mint ...ah well they go back tomorrow cheers davo
Mon Mar 04, 2013 7:24 am
