[ 8 posts ] |
What engine does this gasket kit suit??
Anthiron
Joined: Wed Mar 05, 2014 6:21 am Posts: 57 Location: Sunshine Coast QLD
I have this NOS gasket kit I picked up a long while ago. It is labelled ISUZU 98851-21800 and suits a side flow motor. At the time I thought it was going to fit my G161 however the inlet/exhaust gasket is all off. (The motor in my LUV has square exhaust ports and round inlet ports which is the oppisite in this kit) I haven't had any luck searching the part number on google but I was wondering if anyone on here may know.      Nick
| Sun Nov 29, 2015 9:05 am |
Asroc66
Looks like for G160SS OHC
| Sun Nov 29, 2015 9:25 am |
Asroc66 wrote: Looks like for G160SS OHC yes i have a set for the G180ss and looks very similar except for head gasket size of course.
| Sun Nov 29, 2015 10:07 am |
Anthiron
Any use to anyone?
| Sun Nov 29, 2015 10:09 am |
Asroc66
Keep the rope seals Front and rear rubber sump seals Sump gaskets Timing cover front main seal For you rebuild J
| Sun Nov 29, 2015 10:23 am |
Asroc66
Hi Check these Pistons out
eBay item no.271941108035
Also oil pump EBay item no. 272054716902
Pretty sure this will fit But it is listed for the 1800ss motor
Cheers J
| Mon Nov 30, 2015 3:46 am |
Anthiron
Thanks James,
I have those Pistons saved in my watch list, might wait to see what mine are like first. Managed to find crank bearings, rod bearings, cam bearings (hope these are the right ones), timing chain, std rings and already have a conversion gasket set as well as what can be borrowed from the above. So almost have everything I need on the way I think.
There is also a guy in my local who trades as "gem wreck" so if I need rods and Pistons I'll try him first.
| Mon Nov 30, 2015 4:06 am |
Asroc66 wrote: Hi Check these Pistons out
Cheers J edited
| Mon Nov 30, 2015 6:41 am |
[ 8 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 23 guests |
