Asroc66
Hi Guys Have a seaping front diff main seal where drive shaft mounts I note it has a split pin retained flange Has anyone successfully changed the oil seal with the diff in the car? Or does the whole diff have to come out? Any tricks? Cheers J
| Sun Jul 05, 2015 1:11 am |
Asroc66 wrote: Hi Guys Have a seaping front diff main seal where drive shaft mounts I note it has a split pin retained flange Has anyone successfully changed the oil seal with the diff in the car? Or does the whole diff have to come out? Any tricks? Cheers J I didn't do it myself but had a garage do it for me. Diff stays in the car....... got a seal from local bearing company (info on this group somewhere) BUT...... its still leaking !
| Sun Jul 05, 2015 1:48 am |
Leaky pinion seal.... Welcome to normal Bellett life
| Sun Jul 05, 2015 9:19 am |
CQGT
Hi J.
The number for the seal is. 17446 in Flaseal. P4768 Repco/PBR. Now. This the tricky bit. From what I've found the 2 Companys either don't exist and/or are no longer being manufactured. The bearing company may be able to crossover the numbers to a seal of another brand. I sent my GT diff to a specialist in Brisbane and they sourced all 3 seals from their local bearing comany. They had a sample seal and supplied the dimensions of the housing and the pinion drive flange to them. Procuring them was not a problem. Getting the side carrier bearings was. If you have a slight groove on the pinion drive flange. Enquire about a speedysleeve and purchase some 2 pack araldite to glue it onto tne flange. If they haven't got the parts they may be able to buy them in from another branch and you pay for the freight. Sometimes they can add to an order and you may have to wait a while and not pay the freight. If the seal is either 1 mm under or 2mm over in thickness. Don't dispair. As long as the seal runs on the flange, which it should do, as the seal sits in the housing and has no bearing on the tension or freeplay. Keep us informed. No doubt you will. Happy hunting.
| Sun Jul 05, 2015 10:54 am |
Asroc66
Hi Dave thanks for this info - solid gold I went into my local driveline shop today and showed them a picture of the diff 'No problems mate, piece of piss'......' do em all the time' Ha, we all know where that is heading hey I am planning on getting the brakes serviced later so will add this to the list. Luckily the brake shop and driveline shop are neighbours Cheers J
| Mon Jul 06, 2015 5:50 am |
Asroc66
Eureka It fought me all the way but bit by bit got the yoke off 50 year old Seal hard as hell and a real sh@# To get out lying on your back on concrete at 0' but hey, that's a heat wave in Tassie  .. The yoke will need sleeving as u predicted I am Afraid Cheers J
| Wed Jul 08, 2015 8:11 am |
Asroc66
Speedi Sleave Best invention known to man http://www.bsc.com.au/sites/default/fil ... 6Shaft.pdfThanks Dave Legend
| Thu Jul 09, 2015 6:19 am |
Gunna
Thx for sharing J.
Dean
| Thu Jul 09, 2015 7:05 am |
CQGT
No probs. J. We see this at work quiet often. We had a young fellow advised by his "backyard mechanic" that he would put a new seal onto the rear main crankshaft of his diesel engine but will need an extra thick gasket to have the seal run on a good surface.  This particular seal is mounted in a large bracket and doesn't have a gasket, only sealant.  There were some swear words said that I've got in my black book. I agree. Good invention. Dave.
| Thu Jul 09, 2015 12:52 pm |
CQGT
J. When you start on your brakes keep us posted. I know a couple of 'tips & traps'. Especially on the rears. A 6 foot chain wire fence is a good hand brake. Dave.
| Thu Jul 09, 2015 1:03 pm |
