View unanswered posts | View active topics It is currently Wed Apr 08, 2026 5:49 am
Fuel pump
Car(s): 1968 Isuzu Bellett
Having trouble with the alloy threads in my fuel pump, they are mostly all stripped!
Does anyone know of a fuel pump from another engine that bolts in place?
Tue Aug 11, 2009 1:04 am
Hi, could blank off the mechanical one and use an electric until you find a replacement. cheers, clyde
Tue Aug 11, 2009 4:19 am
Car(s): 2x1967 bellett(white), 99 lancer, 2010 hilux ute.
Quite a common problem, but i have had success with helicoiling(thread insert) them, but gotta dismantle to do it. must be very careful to clean out ALL swarf, as it damages pump valves.Take the banjo bolt in to your local spare parts place, and they should be able to supply you with a kit to do the job. It will be stronger than the origional threads.
P.S. this will also work with damaged diff and gearbox threads :) Hope that helps
Tue Aug 11, 2009 6:03 am
Rethreaded and got some thinner banjos with longer bolts, works well again :)
Thu Aug 20, 2009 10:04 pm
