[ 6 posts ] |
Wanted, info on G180SS valve clearances
Hi All Myself and another G180SS engine owner are looking for clearance specs for inlet and exhaust valves.
Any other similar info would also be nice.
I have the PR60 Sport owners manual and lot's of specs in there but all in Japanese and so far can't decipher what the clearances are, if they are indeed given.
Mark, in UK I assume must know, and some of the Euro group too.
| Fri Feb 25, 2022 4:58 am |
Dick
Joined: Sun Mar 01, 2009 7:18 pm Posts: 95 Location: Netherlands / Holland
Hi Glenn, The inlet clearance on the SOHC 1600 and 1800 is: In - cold is 0.101 mm Out - cold is 0.151 mm There s no rattle, but a kind of rhythm is always there. Gr Dick
| Tue Mar 01, 2022 8:48 pm |
Dick wrote: Hi Glenn, The inlet clearance on the SOHC 1600 and 1800 is: In - cold is 0.101 mm Out - cold is 0.151 mm There s no rattle, but a kind of rhythm is always there. Gr Dick Many thanks Dick Glenn
| Thu Mar 03, 2022 1:17 am |
I scanned a section of my PR60 owners handbook with a Japanese to English translate Ap.
While I had no doubt of Dicks info, it was neat to try the scan and see what it did. (google translate Ap on my phone)
Before and after .............
| Sat Mar 19, 2022 2:48 am |
Pombellett
The clearances are tight aren't they?....don't forget if you're running anything other than a standard cam you might want to open them up a bit. After two munched cams and much head scratching we opted for 0.23 ex and 0.18 in.....and it seems to be working pretty well. Attachment:
| Sun Mar 20, 2022 4:03 pm |
Pombellett wrote: The clearances are tight aren't they?....don't forget if you're running anything other than a standard cam you might want to open them up a bit. After two munched cams and much head scratching we opted for 0.23 ex and 0.18 in.....and it seems to be working pretty well. Hi Mark, I'm no mechanic and to be honest, have never adjusted clearances my self. But the numbers above did seem 'tight'. Sorry to hear 2 cams paid the price. glenn
| Tue Mar 22, 2022 6:22 am |
[ 6 posts ] |
Users browsing this forum: No registered users and 16 guests |
