View unanswered posts | View active topics It is currently Wed Apr 08, 2026 4:04 am
Reply to topic  [ 5 posts ]
Automatic Transmission Info
Hey guys,
Has anyone got a workshop manual for the Automatic transmission in my PR20 please?
I need info such as:
Type - Borg Warner BW35??
Specs - fluid capacity/type (have been using Type F)
Servicing instructions.
Cheers in advance. No rush - just would like to give it a flush and service.
Sat Jan 30, 2016 1:00 am
Exactly the same settings as XP Falcon.
I have an auto glovebox book in my collection with all that info..... But its on display in a museum with 3 of my cars until the end of Feb.
Sat Jan 30, 2016 4:13 am
wait till nq dave gets on he will know
Sat Jan 30, 2016 5:33 am
Hi Redback
I haven't got readily available Bellett Information but if it is a BW35 box then it's the same box as my Triumph Stag ( and many other cars) and the following comes from the Stag workshop manual. Fluid is ATF TYPE F and capacity is given as 8 litres but that includes the oil cooler that the Stag runs. Does the auto Bellett run one? If it doesn't then the next unknown is how much to subtract from your 8 L capacity. Sorry I can't give a definitive answer but it might be if some help. I'd suggest the cooler would only hold about 1L
YP
Thu Feb 04, 2016 8:10 am
Thanks Yellow,
There is no cooler on the Bellett - saying that, in the manual I found for the BW35 it says it should run with a cooler in the tropical climates - Darwin ticks that box.
I might see if I can pick one up.
Thanks for the help and info mate.
Thu Feb 04, 2016 9:05 pm
