| Engine pipe gasket size http://ns2.bellett.net/forums/viewtopic.php?f=34&t=2982 |
Page 1 of 1 |
| Author: | oz_toffa [ Fri Feb 13, 2015 12:49 pm ] |
| Post subject: | Engine pipe gasket size |
standard Bellett 1500 5 bearing main engine. anyone know off hand what is the size of the flange gasket going into the engine pipe, just under the carbi with the 2 brass 14mm nuts on it? thanks OZ |
| Author: | Asroc66 [ Sun Feb 15, 2015 4:54 am ] |
| Post subject: | Re: Engine pipe gasket size |
ACL part no.JE019 Inner diameter 41mm Outer diameter 53mm Cheers J |
| Author: | CQGT [ Sun Feb 15, 2015 1:26 pm ] |
Sometime in '66/'67 Isuzu changed the diameter of the outlet on the manifold. I found this out back in '75 when I took my first PR20 to the exhaust shop. All I wanted to get done was a new inlet on the pipe. The fella measures up the main pipe. Cuts a tube to the size. Welds it to the old pipe. Too small. Checks the outlet on the manifold. Next size up tube. Start again. This time he makes a new seat for the gasket to sit in. I've taken some measurements on the cars that I have here and the distance between the manifold studs as there is also a difference in the retaining plate to hold the pipe into place. Pipe. 45mm (1 3/4"). Plate. 73mm. (2 7/8")..........Pipe. 41mm. (1 5/8"). Plate. 66mm. (2 5/8"). These sizes are pretty close as I just went downstairs about a half hour ago with torch in mouth and verniers in hand. Dave. |
| Author: | Farmer [ Mon Feb 16, 2015 11:51 am ] |
You are a good and thorough bloke, Dave! Cheers, Matt. |
