View unanswered posts | View active topics It is currently Thu Apr 09, 2026 3:07 am
Wasp Generator
Hi, was just wondering if anyone out there knows the make of the Wasp Generator and
if anyone still sells brushes etc for them. :ugeek:
Wed Oct 10, 2012 10:38 pm
I think you may find it's Hitachi, good auto elecics shop should be able to help.
Geoff
Wed Oct 10, 2012 11:04 pm
Thanks Geoff.
I knew the alternators were Hitachi but wasnt sure about the generator. :geek:
The Auto electrician didnt have a clue about the make but found one of the brushes had jammed so
hopefully that will be the problem. ;)
Wouldnt mind keeping a set of brushes spare too 8-)
The make should also help things as well :D
Thu Oct 11, 2012 12:02 am
Josh,
If your current Auto Elect doesn't have them, try another, brushes are normally an easy fix.
Thu Oct 11, 2012 12:06 am
Sorry mate, should of had brain in gear, I read generator and brain said alternator :oops:
Thu Oct 11, 2012 12:47 am
Josh,
I would also make a comment but that would be pointless from someone who knows nothing about electricals so I wont. :roll: :roll: :roll: But you knew that already. And yes the shop is not busy today.
Thu Oct 11, 2012 12:51 am
One of the brushes were seriously jammed and the terminal from the brush holder was nearly broken off,
The insides were on the rusty side :cry:
On the plus side the rest wasnt too bad and with some playing around and cleaning is now working Again :D
Still wouldnt mind confirming the make of the generator :ugeek:
Fri Oct 12, 2012 1:30 am
