View unanswered posts | View active topics It is currently Mon Apr 06, 2026 5:25 pm
Engine pipe gasket size
standard Bellett 1500 5 bearing main engine.
anyone know off hand what is the size of the flange gasket going into the engine pipe, just under the carbi with the 2 brass 14mm nuts on it?
thanks
Fri Feb 13, 2015 12:49 pm
ACL part no.JE019
Inner diameter 41mm
Outer diameter 53mm
Sun Feb 15, 2015 4:54 am
Sometime in '66/'67 Isuzu changed the diameter of the outlet on the manifold.
I found this out back in '75 when I took my first PR20 to the exhaust shop.
All I wanted to get done was a new inlet on the pipe. The fella measures up the main
pipe. Cuts a tube to the size. Welds it to the old pipe. Too small. Checks the outlet on the
manifold. Next size up tube. Start again. This time he makes a new seat for the gasket to sit in.
I've taken some measurements on the cars that I have here and the distance between the
manifold studs as there is also a difference in the retaining plate to hold the pipe into place.
Pipe. 45mm (1 3/4"). Plate. 73mm. (2 7/8")..........Pipe. 41mm. (1 5/8"). Plate. 66mm. (2 5/8").
These sizes are pretty close as I just went downstairs about a half hour ago with torch in mouth
and verniers in hand. :lol:
Sun Feb 15, 2015 1:26 pm
You are a good and thorough bloke, Dave!
Mon Feb 16, 2015 11:51 am
