View unanswered posts | View active topics It is currently Fri Apr 10, 2026 5:15 am
JT Gemini parts supplier.
Hey there guys and girls, Its Rick here from Melbourne.....Mr Gemini 8-) ....from all those years of gemini's i have modified and had in mags over the decades.
With the passing of Laurie Taplin the founder of Alta Imports.
Which i have just bought out all the Jt Gemini parts with factory parts books for Jt191 gemini coupe and sedan and Jt221 piazza, with all specs and info...from Alta imports that were the Jt Gemini specialist........so if you are after any parts which i can supply i will....or order from japan if avaliable.......so contact me if you require any bits and pieces for your jt gemini/piazza through my email.... jt190gem@yahoo.com. 8-)
example: tail lights...headlights and exterior or interior parts.
Thank you....hope to do business with you guys..... ;)
Sat Oct 30, 2010 11:21 pm
Hi Rick
do you have contact for isuzu parts japan as i have been getting some from fastair services.if i give you some part numbers of stuff i know is available do you want to try and get some? as i need a few more. I am sure if you can there would be others that will need bits.
Sun Oct 31, 2010 9:21 am
Yes that fine.
Send me a email through my email address and we will see what we can do for you.
cheers Rick 8-)
Mon Nov 01, 2010 5:33 am
