| 1969 Isuzu Bellett http://ns2.bellett.net/forums/viewtopic.php?f=13&t=84 |
Page 1 of 2 |
| Author: | cute wee gem [ Tue Oct 07, 2008 5:45 am ] |
| Post subject: | Re: 1969 Isuzu Bellett |
Update 9 Due to working on the new daily driver (TE Gemini) and consumption of alcohol, there has been a rather large lack of motivation to work on the Bellett. But, I've made an effort this week now that the Gem's engine is away at the machinist. I bolted on the original Bellett mounts to the twin cam. The drivers side fits on sweet, the passenger side mounting holes are about 10mm further back on the twin cam and as you will see from the photo is sitting on the wrong side of the timing plate and 10mm too far back for the crossmember bracket. Drivers. ![]() Passenger. I also needed to chop the G150 alternator bracket part off as it fouls the timing case on the twin cam. ![]() Just a few misc pics of it all mocked up. Needed to set this all up so I can make sure the throttles won't foul on anything. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Engine isn't actually built, just the bottom end. The head is just sat on there to get clearance problems sorted. Update 10 Pretty good day today. Little better at welding but still not good enough, manifold is in its final position and half welded up. ![]() Here's my little jig from yesterday, making life far easier. ![]() Few pics of the almost finished setup on the engine. Ignore the trumpet spacing, they're not on properly. ![]() ![]() ![]() ![]() Update 11 Got some old bike's exhaust off my mate and found some factory Toyota extractors laying around, so I decided to chop them up and make a template for my exhaust. ![]() Quickly cut out a piece of thick sheet metal for a dummy flange, cut the bolt holes and marked the port spacing. I then proceeded to cut, tack, cut, tack, cut tack.. you get the idea. Just using an arc welder and random pipes as its only a template so its ugly as, but saves wasting decent pipe. ![]() ![]() Thinking about just getting the pipes bent up as one solid piece so I only have to weld them at the flange and collector, perhaps in polished stainless, depending on price. The shock towers on this make it hard to make them equal length without being ugly. I might have a look at just dropping then straight down from the head, but that's no fun! Using http://www.headerdesign.com I got these measurements. With a guess of 150hp (probably a bit optimistic) 35mm primary pipe diameter 800-850mm long primary pipes 55mm collector size (I'll just use 57mm) 330mm long collector |
| Author: | Antti Pellonpää [ Tue Oct 07, 2008 8:59 am ] |
Imagine when you have the steering on the left side as we have here in Finland... I have also made those pipes for my ex 2-liter DOHC Bellett and that was a tight fit |
| Author: | antus [ Tue Oct 07, 2008 11:20 am ] |
That looks like its coming along nicely. Good stuff! |
| Author: | dave [ Tue Oct 07, 2008 11:31 am ] |
Antti Pellonpää wrote: Imagine when you have the steering on the left side as we have here in Finland... I have also made those pipes for my ex 2-liter DOHC Bellett and that was a tight fit Oh yeah didn't think of that! Complicated!! |
| Author: | 2ldohc [ Wed Oct 08, 2008 4:07 am ] |
Great bunch of pics! Any idea how far off completion you are? |
| Author: | Barney [ Wed Oct 08, 2008 7:13 pm ] |
Oh man, I wish I'd seen that pic before you, chocolate brown looks HOT! |
| Author: | cute wee gem [ Sun Oct 19, 2008 3:35 am ] |
Scrapped my exhaust template and am going to start again on it soon. Lately I've been doing a bit of research on ignition and how I'm going to go about getting this thing running, so I haven't had a lot of time to actually get out and work on it. Been out playing with the front pulleys to get them lined up. Ended up using a g161z crank pulley, taking the inch thick spacer off the g200w water pump and I'll need to get the water pump pulley spacer spun down to line them up, and make a spacer for the alternator pulley off the original g150 This should all give me plenty of room for the radiator, and I can mock my exhaust up with the alternator in its final position. I also need to modify the water gallery/thermostat housing. Slowly getting a bit better at this welding business. ![]() I got this collector off kpr from the www.oldschool.co.nz forums, he made a couple of reducers aswell.
| Author: | 65bellett [ Tue Oct 28, 2008 8:18 am ] |
Love your work mate, very impressive. I noticed some where else on the forum you were chasing a plate to cover the radio hole. If you get stuck I have a few in my shed that I could post to you. P.M when and if you need it. GAv |
| Author: | cute wee gem [ Sun Feb 01, 2009 5:21 am ] |
Well, I have literally done nothing on this for a while now. As I have been busy with my TX Gemini (project daily driver) so here's a couple of pics of why I haven't been working on the poor ol Bellett Link to my TX build up http://www.oldschool.co.nz/phpbb/viewto ... 17&t=16586 Work should start on the Bellett in about a month or so, you should start to see some updates soon. |
| Author: | 2ldohc [ Sun Feb 01, 2009 9:22 am ] |
Fair call... The little Gem looks pretty good even if you think the body could have had more prep. Looks good and those wheels really set it off Cheers for sharing another Isuzu project with us. Post pics in the 'Other Isuzu' section if you want it up here for all to see Cheers, R. |
| Author: | Waldo [ Tue Feb 22, 2011 7:50 am ] |
hey mate what is the part number for the fidanza flywheel you have there? im trying to get one from fidanza but they say none suit the g200w |
| Author: | oz_toffa [ Tue Feb 22, 2011 12:02 pm ] |
Your sure keen to get those cars tidied up and running well. Love your port and polishing too. Thanks for all the great build photos. Keep those pics coming OZ |
| Author: | Nakazoto [ Tue Feb 22, 2011 9:21 pm ] |
This build is pretty epic! You're doing an unbelievable job! Keep up the great work Thanks David |
| Author: | PR95 [ Tue Feb 22, 2011 9:34 pm ] |
The last post there was 3 years ago, wonder if it was finished? |
| Author: | GTtoo [ Tue Feb 22, 2011 11:40 pm ] |
Awsome effort cwg. One hot sedan/gt coming up !! B. |
| Author: | yellowperil [ Wed Feb 23, 2011 11:18 am ] |
Thanks for sharing such a great lot of photos. This is fantastic and inspiring work |
| Author: | redback [ Wed Feb 23, 2011 9:50 pm ] |
You are a very talented bloke - great insight into what you have done. |
| Page 1 of 2 | All times are UTC |
